Hello,
Got a new (to me) CB750 project. It is a 1972 (K1). I know much on the front end is not correct K1. For example, the fender appears to be off a 77 or 78 and the chromed headlight ears should be painted. So, I know the front end probably has been replaced at one point.
The forks in a lot of ways look correct except the air shrader valve on top. I know the earlier CB750's weren't air assisted, but was there air forks on later models?
If so, any guess what these might be off of??
If everything else seems solid as I get deeper into this project this winter, I will likely try to get the bike back to as many correct parts as I can, but it would be nice to know what I'm starting with.
Any guesses as to what year this front end it from?
Thanks
