Author Topic: Gasket material fell where it shouldn't  (Read 761 times)
andmoon
« on: June 05, 2008, 04:24:07 AM »
I diligently wrapped the 4 pistons and filled the gaps betwwen the block.
I dabbed gasket remover via brush not to remove paint, smoked a cig., to fight the fumes, scraped away another bit, repeat.
I was hard at work between #3 and #4 when I noticed #2 couldn't bear the heat and took off it's clothing.
I have no idea if or how much of the gasket crumbs fell into the block.
What to do now?
Vac and hope for the best?
Re: Gasket material fell where it shouldn't
« Reply #1 on: June 05, 2008, 05:29:16 AM »
At 500 miles drop the sump and clean the pump filter
andmoon
« Reply #2 on: June 05, 2008, 09:49:14 AM »
Thanks!
I am glad to hear there is a pump filter.
« Reply #3 on: June 05, 2008, 08:09:54 PM »
If its a 750 the pump filter is on the return anyway as the oil feed is from the tank
