Author Topic: CB750K1 COUNTERSHAFT BEARING REMOVAL (6304)  (Read 3996 times)
Offline unlord5150
« on: June 07, 2008, 11:15:53 AM »
I have to remove the 6304 bearing from the countershaft bearing holder on the outside of the case.  Does anyone have suggestions on how to accomplish this?
'71 CB750K1 Ruby Red, currently in pieces all over the garage.
'75 CT90, family heirloom.
Offline mystic_1
  • 1970 CB750K
Re: CB750K1 COUNTERSHAFT BEARING REMOVAL (6304)
« Reply #1 on: June 07, 2008, 06:00:28 PM »
I got one out by freezing the assembly, the bearing popped right out then.
mystic_1
- John Augustus Shedd
« Reply #2 on: June 08, 2008, 08:14:10 AM »
If it the one with the groove and clip , you will be pulling the motor and splitting the cases..
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: June 08, 2008, 08:31:52 AM »
Nah, the 6304 bearing on a 750K1 is the one that rides in the countershaft bearing support under the mission cover.
Bearing sits onside #1 in the following pic, no need to split the cases.
mystic_1
Offline unlord5150
« Reply #4 on: June 08, 2008, 09:20:39 AM »
Yup, that's the one.  I've got it in the freezer right now, hopefully that will do the trick.
« Reply #5 on: June 08, 2008, 09:35:06 AM »
Oh that one..heat it to 250, and it should fall out.
