Have you tried testing the light sockets with an ohm meter? from the center pin to ground with no wires hooked up it should read open. If not that is your culprit. Also did you use a large enough guage wire for the bulbs? Test this by removing the wire from the light socket, remove the bulb, and ground the outer metal portion to the frame or ground on the battery. then touch the wire to the center pin on the bulb. If the bulb lights, then you probably have a short in your light socket, if it blows the fuse, then you have too small of wire feeding the voltage to your socket.
Good luck!
Hondalubr
