As long as the rubber is not damaged and still 'squeezes' into the hole (ie it hasn't shrunk from age) then you're fine. It is not included in gasket sets, IIRC. In a pinch you could probaby carve a replacement out of some other rubber bit, it's really just a fancy cork. If you do that, make sure you don't block the passage.
mystic_1
