Author Topic: '78 750f throttle return spring and the 'push' cable  (Read 842 times)
Offline dboblet
  • OMG - what did I get myself into this time!!??!!
« on: June 29, 2008, 07:51:35 PM »
I've noticed that the return spring is very strong.  this means that the 'pull' cable gets a lot of return action.  Frankly I can't see any need for a 'push' cable and I've been thinking of eliminating it.  Is there any 'really' good reason for leaving it.  The one I have is the original (new pull cable though) and has some resistance in the old case (rust I suppose).
No matter where you go, there you are.
Offline 75750SS
  • 75 750F, 2010 Concours ABS
Re: '78 750f throttle return spring and the 'push' cable
« Reply #1 on: June 29, 2008, 07:57:06 PM »
The only thing I can think of is if the spring broke (not likely), you could still push via the cable.
Offline shoemanII
  • just another bike nut
« Reply #2 on: June 29, 2008, 08:02:07 PM »
i backed off on the throttle return spring about 1/2 wrap or so (one end is now hooked over the rear bar that connects the carbs).  throttle action is much easier, but the push cable is needed.  almost feels like the throttle on a FI bike.  this, i think, is frowned upon by some but i'm old.  i do what i want.
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline dboblet
« Reply #3 on: June 29, 2008, 10:58:19 PM »
"this, i think, is frowned upon by some but i'm old.  i do what i want."
You make me laugh.... no, Really.  I laughed, and out loud too!!  I applaud your attitude.
