So after searching extensively, i think my question is even too naive to have been discussed before. Please remember this is my first bike of any kind, so I am still working out what is "normal" and what isn't.
Its a cb350F, not running (waiting for throttle cables), and I am just finishing up giving everything a once over/rebuild/adjustments/tune ups.
One thing that i have noticed, moving it from my driveway to work area, is:
---when the bike is in neutral, it glides effortlessly
---however, when i am in gear (doesn't seem to matter which one), but have the clutch lever all the way pulled in, it is much harder to move (but will with some encouragement). I have adjusted the clutch lifter arm and cables 3x, but nothing alleviates this problem. Is the clutch actually dragging, or is the bike turning the engine over (effectively increasing resistance), even with the clutch disengaged?
Again, it is not running at the moment, so i am just trying to diagnose everything as it is, so i don't know how this actually affects riding conditions. The bike shifts just fine in all gears, and is rock solid when the bike is in gear, and the clutch cable is silky smooth.
In the same note, per instructions from the service manual, there is an adjustment screw that, once the lifter arm mark and the plate mark align, that i screw all the way in, then back out 1/4 turn before locking in down, and all subsequent adjustment is through the clutch cables. What does this adjustment screw do? I assume that it is moving the actual clutch assembly, so if i back it off more than 1/4 turn, will that alleviate the problem, if in fact there is one?
Nothing like a new hobby to deflate ones ego.....
