Author Topic: neutral light quandary  (Read 1022 times)
Offline johnyvilla
« on: July 08, 2008, 09:10:54 PM »
I just plugged a new motor into a K5 roller this week. Everything works well save for a neutral light of perpetual glimmer. The wire has a good connection but I cant figure out why its stays on. Any ideas?
Offline KB02
Re: neutral light quandary
« Reply #1 on: July 09, 2008, 05:17:24 AM »
I had the same issue on my F1. Tuned out that a replacement o-ring was too thick and didn't let the switch go far enough into the crank case. A smaller o-ring fixed the issue.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Kevin D
  • SE Michigan
« Reply #2 on: July 09, 2008, 01:52:24 PM »
+1 on that. I replaced all orings and seals this past winter and came up with the same problem. I did a little searching here and then put my 37 year old OE oring back on the neutral light switch and its good as can be. The part is spec'd at 18 x 3mm, but the oring supplied by Honda was just a little too fat to let the NLS seat all the way into the case.
71 CB750 K1
106,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline johnyvilla
« Reply #3 on: July 09, 2008, 03:24:47 PM »
Hmm. All I did was reconnect the ground lead. I used the same O-ring as before.
Ill take a closer look at it.
thanks
Offline jtb
  • An unlikely
« Reply #4 on: July 09, 2008, 06:23:23 PM »
Johnny, I had the same problem with mine.  I pushed on it while moving the shifter lever up and down, and it finally seated.
John
1977 CB750F
1985 V65 Sabre
