Author Topic: 650 550 exhaust  (Read 1205 times)
1981cb650c
650 550 exhaust
« on: July 12, 2008, 12:36:34 PM »
yes I searched, too many references to 650 and 550 and exhaust to locate anything useful.
Will a 650 exhaust fit on a 550? will a 550 fit a 650?
Offline CBGhia
Re: 650 550 exhaust
« Reply #1 on: August 24, 2008, 11:34:11 AM »
ok,  I know this is an old post, but I searched as well and couldn't find the answer. Will a 650 exhaust fit on a 500/550?
Offline DarkRider
Re: 650 550 exhaust
« Reply #2 on: August 24, 2008, 01:32:13 PM »
Short answer..No. Asked the same question when i was researching ways to up the power of my CB550. The only time you can really use a 650 Exhaust on the 550 is if you swapped on a 650 head. Not sure if its because of downpipe length or pipe dia. Im assuming its a bit of both.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
tx650
Re: 650 550 exhaust
« Reply #3 on: August 24, 2008, 08:32:08 PM »
The 550 exhaust is 1-1/4" OD and the 650 is 1-3/8" OD. I put the engine from a 1975 550 in my 1980 650 for a while. The installation was fairly easy but had to use the 4 into 1 exhaust from the 550 because of the differences in OD. The 550 exhaust fit the 650 frame OK.
It was nice to have a kick start option on the 650.
Offline InTheStreet
  • Ha, you let me be a
  • When in doubt, flounder about.
Re: 650 550 exhaust
« Reply #4 on: June 25, 2013, 07:50:18 PM »
Just installed 650 exhaust on my 550, but it took a little bit of work.  As TX650 said, the pipe diameter is different, but they are perfect for cutting and combining.  Here's how I did it, since I found this question asked a few times when I searched for the answer myself.
I cut the 550 head pipes 8 inches down the pipe (measured on the inside of the curve)
I cut the 650 header 6 inches down each pipe (again, inside of the curve)
Slid the 550 head pipes into the 650 header
   -keeping each head pipe in the position from which it came [ie: cylinder 1 stayed with cylinder 1, etc] not sure if this is
    necessary, but there did seem to be some subtle difference between the various bends
   -some of the 550 pipes had to be squeezed and "worked" with a hammer at the cut end to fit inside the 650 pipes.  nothing
    major, just minor adjustments.  Some of the 550 pipes were cut near a bend, which made the pipe not exactly round
I bungee corded the exhaust to the bike (650 bracket on the cone [muffler?] is further back, so you can't just slide a bolt in)
With the exhaust held up sorta where I wanted it, I turned the various 550 head pipes around and wiggled them up and down until they all were able to slide into the head.
I put the exhaust pipe joints and collars loosely on the pipes for 1 and 4 just to make sure the pipes would pull up into the head correctly.
Then I marked the pipes excessively with permanent marker.
All but one pipe stayed put on the trip to the welder.
Had a buddy TIG with stainless wire.  He did a great job, and after he hit the welds with a wire brush, they were the nicest looking part of my whole system.
I bungee corded the completed pipes to the bike again, wiggled them into place with the joints on the pipes, put the collars on one cylinder at a time.  To tighten the joints, I pushed in until I could start one of the nuts without the lockwasher.  Once I had one nut on each cylinder, I went about tightening the nut a little, then tapping the other side of the joint to pull it up closer until I could fit the lockwasher and nut on the other side.  Then I would remove the un-washered nut, washer it and tighten it down until it was even with the other side.  I tightened each nut a little at a time and drew the "new" exhaust up into the crush gaskets.  If I had been more patient and cautious in the mock-up phase, I may have been able to avoid doing all of this during the final assembly, but I figure I'll just tell you what worked for me.  In the end, the "new" exhaust fit so well I was even able to reuse my copper crush gaskets without a leak. (I really wanted to see if I had pulled it off, and couldn't wait.)
To correct the rear bracket, I used a rear tire adjuster from a CB650, pointed the adjuster bolt down and back, put an "L" bracket on the bolt, "locked" it into place with nuts, and bolted the "L" bracket to the tab on the 650 silencer/muffler/cone.
Right now, the center stand pushes on the cone/silencer/muffler as I put it down (clears when up or down easily), so I am considering adjusting the "L" bracket to push the cone out away from the bike a little further.  I just don't want to put strain on the head and cause warping over time when I could just hammer in a dimple on the cone to give me the inch or less of clearance I need. (I have not taken any pictures of this yet, as it is still a work in progress.)
Basically, this created a stepped or step up exhaust system like many aftermarket systems and allowed me to use what I had in the garage (plus a friend who is a good welder). I rented a chain tailpipe cutter from AutoZone, so I paid and then got my money back.  Other than the very reasonable amount of money my friend wanted to do the welds, I spent $4.18 on hardware and it took me about 4-6 hours.
So, can a 650 exhaust fit a 550?  Sorta
*Note: the bottom picture is from the mock-up stage; I added it at the last minute to show how I bungee corded the pipe up.
« Last Edit: June 25, 2013, 07:52:13 PM by InTheStreet »
1975 CB550K1
1980 CB650C (parting out)
1980 GL1100 (sold and missed)
Offline Bankerdanny
  • Endeavor to persevere
Re: 650 550 exhaust
« Reply #5 on: June 26, 2013, 08:43:07 AM »
Just goes to show, pretty much any part from one bike will fit another if you are willing and able to take the time and effort to make it fit.
But the short answer to the original question is no, the 550/650 exhausts are not cross-compatible.
