Author Topic: CB550 76 Carburetor synch instructions?  (Read 1513 times)
Offline 76CB5WI
  • CHRIS
« on: July 13, 2008, 06:10:39 AM »
Im getting ready to buy a manual which I should but can
anyone point me to a carb synch link on here.
It doesnt seem to be covered in the online manuals, maintenance..etc.
What I mostly need to know is
Where are the adjusters?
Under the big brass Hex heads? or the little external silver nut/screw combos
with the spring steel bands between each set of two. I have heard no 2 is the reference carb.
Thanks for any help
CB5WI-cbwick@live.com
87 FJ1200
72 CB750
76 CB550
Offline Pawsoff
Re: CB550 76 Carburetor synch instructions?
« Reply #1 on: July 13, 2008, 07:11:42 AM »
if you look in the FAQ you will find the service manual for the cb500/550, in this manual is the description of how to do the carb sync.
Pawsoff
1977 CB550F
On the road, slowly improving the bike :)
Offline 76CB5WI
  • CHRIS
« Reply #2 on: July 15, 2008, 09:10:56 AM »
Thanks, I found this a while back but..funny thing the carbs in the manual were different than my Keihin a87s which are the stock units. Im going to assume that the
external silver nut and threaded shaft on top of each adjuster is where the adjustment is made.
What puzzles me is that there are 4 of them and carb 2 should not have an adjustment?
87 FJ1200
72 CB750
76 CB550
« Reply #3 on: July 15, 2008, 09:13:44 AM »
The carbs for the K3 are quite different from the earlier carbs.  Your's should look like and operate like the ones in chapter 4.
Offline ieism
« Reply #4 on: July 15, 2008, 12:46:09 PM »
Sometimes all carbs can be adjusted...like on my 550F '76 carbs. I didn't see that in any manual either, but if you have 4 adjuster screws they just are.
And don't waste time doing a carbsync for 2 hours. You won't get them better than in the first ten minutes anyway. They keep moving out of sync .....
Just stop after 10/15 minutes.
---cb550---
