Author Topic: cb750 rear sprocket  (Read 2030 times)
Offline jreich
cb750 rear sprocket
« on: July 20, 2008, 02:41:08 PM »
I'm trying to determine the year 750 that this rear sprocket came off of, so that I can buy a 37t. This one is a 48t.
The distance from hole to hole is 3 1/8" center to center.
There may a an easier way to determine what year hub this is, so if there is, I'm all ears.
Thanks in advance.
JD
Offline Gordon
  • 750K1, 550K2
Re: cb750 rear sprocket
« Reply #1 on: July 20, 2008, 03:00:07 PM »
The bolt holes on my K1 sprocket measure the same as that one, so any sprocket made for a 750 up through K6 should work.
Just curious, why such a big change in gearing?
Offline jreich
« Reply #2 on: July 20, 2008, 03:07:19 PM »
I am using a 750 rear hub laced to a 16" rim on my cb550 build.
My old gearing was 16t up front and 37t on the old 550 hub in the rear.
Would using a 37t 750 rear sprocket equate with using a 37t 550 rear sprocket?
Is the width of the 550 and 750 rear sprockets the same, so that I can use the same old stock 550 chain?
whew...thanks for the help
JD
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: July 20, 2008, 03:54:12 PM »
Yes, the sprocket width is the same because both bikes use a 530 chain.  Have you checked the difference between the hub widths?
Offline jreich
« Reply #4 on: July 20, 2008, 04:01:17 PM »
Thanks so much Gordon...I greatly appreciate it
I never did measure the difference in hub width between the 550 and 750.
I am using this on a hardtail that I bent up and welded on, and therefore fabricated spacers to accommodate this specific hub and to achieve the correct chainline.
Thanks again for the help Gordon
Cheers
JD
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: July 20, 2008, 04:03:36 PM »
Cool!  Pictures will be required when you're finished! ;D ;D  (or even before you're finished)
Offline jreich
« Reply #6 on: July 20, 2008, 04:35:02 PM »
Here are a few pictures of where I was at a few weeks ago....
http://forums.sohc4.net/index.php?topic=36458.0
Haven't had much time to take pictures in the meantime, but have handrolled a fake oiltank to house the electrics, and done a number of other things.
It is really amazing how much goes into a ground up build....as this is my first, I'm learning what works (and what doesn't) for next time.
Speaking of next projects...I just picked up a '63 Triumph TR6SS engine that I will be working on, and building up over the winter
So, I should quit rambling as I just took this thread from sprocket identification to Triumphs....
thanks again Gordon...much appreciated.
JD
