Author Topic: CB400F Plug Wrench Question  (Read 3916 times)
Offline Senna27
« on: July 26, 2008, 11:59:19 AM »
What size plug wrench do I need to remove the plugs on my '75 CB400F?
The Toys:
1975 Honda CB400F
1975 BMW 2002 - Jade - Daily Driver
2010 Toyota Matrix XR - Winter Beater
(2) 2008 Sea-Doo RXP-X
  • I'm back
Re: CB400F Plug Wrench Question
« Reply #1 on: July 26, 2008, 12:07:32 PM »
I strongly advise you to use the original Honda plug wrench (toolset). The wrench has a rubber part deep inside that prevents damaging the sparkplug.
Offline Senna27
« Reply #2 on: July 26, 2008, 12:10:33 PM »
I can purchase a plug socket with the rubber grommet inside but I need to know the size!
The Toys:
1975 Honda CB400F
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #3 on: July 26, 2008, 12:11:41 PM »
It also depends on the brand of plug. I have a set of Champions and a set of NGK for my bike (it's a 550 however) and the Champion is a 5/8" and the NGK is an 18mm.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
  • I'm back
« Reply #4 on: July 26, 2008, 12:22:00 PM »
18mm hex but.... not every plug wrench can make it through the hole.
Offline Senna27
« Reply #5 on: July 26, 2008, 12:33:06 PM »
They are NGK DR8ES-L
The Toys:
1975 Honda CB400F
Offline Senna27
« Reply #6 on: July 26, 2008, 12:34:13 PM »
OK... I'll make sure I measure it so that it fits.
The Toys:
1975 Honda CB400F
Offline dave400
  • Super Lamb Banana
« Reply #7 on: July 26, 2008, 01:10:48 PM »
If you have resistor type spark plug caps (It's an original Honda part)....... are you? Then you should be using NGK D8EA plugs. I have 5KΩ NGK caps on my bike and it's direct replcement for the honda part.
dave m
« Reply #8 on: July 26, 2008, 01:16:40 PM »
IIRC it should be 18mm.
You still got those alloys on your 400F Dave?
Offline Senna27
« Reply #9 on: July 26, 2008, 02:04:23 PM »
I have a Dyna S Ignition System and aftermarket plug wires w/o resistors. That's why I need the DR8ES-L.
The Toys:
1975 Honda CB400F
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: July 26, 2008, 02:46:59 PM »
I have a cheap, long reach, thin walled 18mm that I use for spark plugs.  Works great and fits easily into the plug recesses for the difficult #2 and #3 plugs.  It doesn't have the rubber grommet, but I've been using it for several years and never once damaged a spark plug.  I always thought those were put in spark plug sockets to hold onto the plug to keep it from falling down into an engine bay.  Not something you need to worry much about with a bike.
Offline Senna27
« Reply #11 on: July 26, 2008, 04:13:46 PM »
Yeah, the grommet helps hold the plug in place. Just bought an 18mm spark plug socket and changed my plugs. All good, thanks for the help guys!
The Toys:
1975 Honda CB400F
