Author Topic: Blubbering 750 at 1/8  (Read 1126 times)
Offline johnyvilla
« on: August 05, 2008, 06:41:54 AM »
How much blubbering at 1/8 throttle is acceptable? My K6 is stock save for a 4 into 1 with electronic ignition, and I cant believe those mods would warrant a different pilot jet. All my tune up bases are covered: Valves, timing, sync, cleaned carbs, etc. I wouldn't mind so much except that slow speed cornering is dicey with the uneven power at this throttle opening. Engine idles best around stock air screw settings. Any suggestions?
Offline GammaFlat
Re: Blubbering 750 at 1/8
« Reply #1 on: August 05, 2008, 09:27:56 AM »
I have a K6 with a Dyna-S and Mac 4-1.  I'll check my jets and my plugs and let you know what I find.  I'm sure that my jets are not stock - I think mains are 105s from factory?!  My mains are probably currently way too high.  It seems to run great but I have to look at the plugs....
My plans are to jet down - probably close to factory if not factory, go to HM341s (just got a new set) and run the HondaMan ignition instead of the Dyna-S.
K6
85 Goldwing
martino1972
« Reply #2 on: August 05, 2008, 09:52:56 AM »
did you try to raise the needles one notch..????
did you do a plugchop....
Offline johnyvilla
« Reply #3 on: August 05, 2008, 10:30:13 AM »
Ive adjusted the needles and mains properly. The bike runs great from 1\8 on but stumbles a bit below. Ive heard that you shouldn't have to touch the pilot jets in less you radically change your engines breathing.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #4 on: August 05, 2008, 11:28:08 AM »
1/8 i still pilot jets.
Sounds a bit rich.
Hows your air filter?
Turn the airscrews out another quarter turn (turn them in first to get your baseline). See how it goes.
No.
Offline chrislib
« Reply #5 on: August 05, 2008, 05:28:35 PM »
I had/ have a similar thing going on. My bike was a bit rich, I dropped the needles to the 2nd from top, made a good bit of improvment. Then I put the air screws at 1 3/4 (had them at 1 turn out). Even better but still there a touch, depending on the air temps, bike runs "cleaner" on a cool high barometer day (like today). Oh mains are 120`s, pilots???? (stock), stock airbox w/paper filter, 4into1 and elec ign. Hope it helps.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
