Author Topic: 1980 cb650 carbs  (Read 1504 times)
dancaudill
1980 cb650 carbs
« on: August 11, 2008, 11:09:16 AM »
i just bought a 1980 cb650 custom friday with klien carbs..i would like to put a aftermarket or make a set of pipes for it  and individual pod filters on it but from what i am seeing i cant jet the carbs..so does anyone know a way to do it or is there a different set of carbs i can swap into it that are jettable..any help is greatly appreciated..
Offline cb650
Re: 1980 cb650 carbs
« Reply #1 on: August 11, 2008, 05:18:31 PM »
Main jets are replaceable.   If you grind of the tab on the idle screw or the bowls you get around that limit.
dancaudill
« Reply #2 on: August 12, 2008, 02:08:33 AM »
i new the mains were..i just didnt know what to do with the low speed jet..what tabs are you talkin about..
Offline tonycb650
« Reply #3 on: August 12, 2008, 03:59:14 AM »
hes talking about the pilot screws. you can unscrew them after you take off the float bowls. usually, you dont have to change the slow jets , just richen the pilot screws.
80cb650c 80 cm400
Offline eurban
« Reply #4 on: August 12, 2008, 05:25:01 AM »
Yes and if your carbs are the slider variety with non adjustable main jet needles, use small washers underneath the clip to richen operation under mid throttle conditions.
dancaudill
« Reply #5 on: August 12, 2008, 10:18:46 AM »
ok..thanks for all the help
