with an aftermarket pipe you will need to work out how your going to stop the stand from rubbing on the chain. Both types of OE pipe have a rubber stop that lines up with the centerstand when it's raised. There may be something already there or it's quite easy to fabricate something, a rightangle fixed to the footpeg mounting point should do the trick. Just something to be aware of, that's all.
