Author Topic: The Works  (Read 850 times)
WHALEMAN
The Works
« on: September 03, 2008, 07:48:42 AM »
Does the "WORKS" toilet bowl cleaner that eats rust inside the tank hurt the paint if some is spilled or sloshes out?
Offline karmasic
  • pull-a-part boy
Re: The Works
« Reply #1 on: September 03, 2008, 08:28:34 AM »
many posts on the works. search and know more then you ever wanted.
rockwell500k
Re: The Works
« Reply #2 on: September 03, 2008, 09:35:06 AM »
i used this non-caustic stuff from home depot called "zep".
diluted with warm water, let it sit for several hours and rinse and dry.
i'd say it got rid of 95% of the nasty stuff, and left a small expected amount of surface rust.
i gave the inside a quick shot of WD40 afterwards, then filled with gas as normal.
