Author Topic: cb550 exhaust swap  (Read 1718 times)
Offline R. Hykawy
  • 77 CB400F Winnipeg,Canada
cb550 exhaust swap
« on: September 12, 2005, 07:37:46 PM »
Hi, I've been searching through previous posts looking for the answer to my question,but have been unable to locate an answer. What I need to know is if the the exhaust system from a 550f will bolt up directly to a 74 550, without any modification? I have the opportunity to puchase the 74 for$200 Cdn. but it needs a complete exhaust system and I already have one for the 550f.
Richard Hykawy
Re: cb550 exhaust swap
« Reply #1 on: September 12, 2005, 09:25:39 PM »
The interface with the head on the engine is the same for all CB550s.  However there are differences in the frame mounts for the muffler.  I expect and adapter can be made for that.
The right foot peg and perhaps the kick starter are different, I believe, on the F to compensate for a larger bulk of the system there.
I've not tried the swap, personally.  Just some observations from my examples of the models.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #2 on: September 13, 2005, 03:12:44 PM »
My '78 550K has an F header on it. As TT says, the right peg pivots differently to clear the kick-starter, I haven't ever needed the kick. Other than that you'll need the brake pedal from an F, or make your own. Also, the collector will come up slightly against the foot-peg nut, so use new exhaust gaskets.
Kawi GPz900, H1
El Taco
« Reply #3 on: September 13, 2005, 08:03:54 PM »
It does not work. I have two nice F model headers, but my F is F'd at the moment. The frame of the F incorporates a different left footpeg, the kick is indeed different, and the kickstand is in a different place.
« Reply #4 on: September 13, 2005, 08:26:02 PM »
Are the frames  of '74 and '78 K's that different?
Kawi GPz900, H1
« Reply #5 on: September 13, 2005, 08:31:39 PM »
I can't see what the left peg and kick-stand have to do with it.
Kawi GPz900, H1
