Author Topic: small ring compressor  (Read 2126 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: September 15, 2008, 11:13:02 AM »
i know there have been several threads describing people's methods for compressing piston rings during a rebuild, but i've not seen anyone list a source for a small ring compressor. anyone? i usually use my fingers and wooden sticks, but i'm doing an 850 kit right now with rings that just don't want to go that way. sure don't want to fold an oil rail on an 850 bore...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Triffecpa
Re: small ring compressor
« Reply #1 on: September 15, 2008, 12:57:27 PM »
check Pitposse.com
They sell a ring compressor with three different bands to accomodate different piston sizes.  You'll need two of them to do a four cylinder engine.
Pretty reasonable on price.  $24 or something for one.  Cheaper than replacement piston rings...
Here's the direct link.
http://www.pitposse.com/piriin.html
Tracy
Offline Magpie
« Reply #2 on: September 15, 2008, 01:27:45 PM »
I used large radiator hose clamps as ring compressors. Worked fine just don't tighten them up too much. They will slip down the piston as the rings enter the bores.
Cliff.
Offline paulages
  • 1976 cb735
« Reply #3 on: September 15, 2008, 02:42:13 PM »
Cliff.
the problem i've had with hose clamps is that the inner surface is not continuous. I've made them work before, but don't like them.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #4 on: September 15, 2008, 02:53:47 PM »
check Pitposse.com
Tracy
thanks! all of the ring compressors i've seen in this style don't go small enough to fit these pistons.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline SD750F
    • My Business Site
« Reply #5 on: September 15, 2008, 03:20:08 PM »
I picked up a pair from a Norton/Triumph tool supplier on eBay. They are made for 60-65mm pistons which is perfect for the typical 750 61mm piston.
Scott
« Reply #6 on: September 15, 2008, 08:07:59 PM »
I used a HASTING compressor, on a lot of different pistons. It works very well, not sure of minimum size tho or part number.. got it 20 or more years back.
Similar in construction to a hose clamp, but wider, smoother and has a quick release to get it off.
