Author Topic: oil leak  (Read 1674 times)
cd811
oil leak
« on: September 14, 2005, 06:31:28 PM »
got all my oil leaks fixed but one
the left side, stator area
replaced and super cleaned everthing added some nonhardening goo...still leaks
one questionable area...where the wires pass though some of the rubber is missin..added extra goo there...still leaks
any experiece or suggestions?
could it be coming from the cover next to it(by the shifter)?
Offline kghost
Re: oil leak
« Reply #1 on: September 14, 2005, 08:05:21 PM »
Yes it could......
Could be the cover is warped. Check it with a flat peice of glass and a feeler gauge.
Ya put a gasket on it right?
Stranger in a strange land
scottgarland
Re: oil leak
« Reply #2 on: September 14, 2005, 08:19:46 PM »
There is a good sealer for older bikes and cars Wurth DP300 in a tube follow directions, and if case isn't warped this will seal a 1mm variation. My other passion is old english bikes. England didn't invent oil leaks but they damn sure perfected them.
Offline jotor
Re: oil leak
« Reply #3 on: September 14, 2005, 08:27:21 PM »
Which came first--the Brittish bike or the Corvair?................
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
cd811
Re: oil leak
« Reply #4 on: September 15, 2005, 04:51:39 PM »
yes I've used two new gaskets
never heard of that sealer. where did you find it?
thanks for the responce!!
Offline Chris Liston
Re: oil leak
« Reply #5 on: September 15, 2005, 06:59:49 PM »
Yamalube sealer.  cures all.  Available at your local Yamaha dealer
1976 CB550F Cafe in progress
Offline chrometank
  • cb750 1976 owned 33 yrs
Re: oil leak
« Reply #6 on: September 15, 2005, 08:10:10 PM »
Had exactly the same leak and it was where the wires go thru the cover,after a few goes at fixing it I put some thick gasget goo on it and it worked well
