Done. They looked like this originally, like the old worn ones in this pic:
I stripped them with acetone. I first tried hand painting them with enamel. Big waste of time. It looked horrible, so I stripped again and decided to spray it and remove the top layer on the raised letters. I sprayed three healthy coats of flat black, and first tried just rubbing off the top layer with a blue paper towel with a bit of acetone, but that was time consuming as it was pretty thick. I instead used a razor to scrape most of the paint off the letters and then went over with the acetone, which worked much better. The letters themselves are pretty knicked up, from 33 years of who knows what, but they're much better than before.
the plan is to put a couple layers of the spray max two part clear coat that is fuel resistant on them, giving the black a little more glossy look. Now I just need to find that stuff.
