Author Topic: Beware of synthetic oil  (Read 7913 times)
Offline Paul
« on: April 14, 2005, 01:01:56 AM »
I just had to share this. (Stolen :D)
"Beware of synthetic oil, it can do terrible things to you and your beloved motorcycle. It will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system. It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action. Then it will leak onto your kickstand causing it to retract automatically, dropping your bike on the ground! But that's not all...
Synthetic oil will round off your gears and spin your bearings. It will also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and she'll never ride with you again. Synthetic oil coats your sight window and your timing window with a whitish pro-emulsification additive that is both non-removable and highly corrosive.
Synthetic oil will completely leak onto the ground overnight and your dog will drink it and die. Synthetic oil will wear out your tires and make your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam your zippers shut. It will contaminate your gasoline causing your bike to stall on railroad tracks and accelerate uncontrollably near police cars. It will make it rain during rallies and on weekends. It will lubricate your timing belts causing them to jump teeth and break your valves to bits.
Synthetic oil chemically weakens desmodromic valves and causes the clearances to change every six miles. Then it melts the black soles of your riding boots right before you walk across your new carpeting. While riding past groups of attractive women it will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose. It also causes your swingarm to crack, your studs to break, and your rotors to warp, and then it voids your warranty by changing your odometer reading to 55,555. It also dries out your wetclutch and wets your dryclutch. It makes your clutch slave cylinder seal fail in the heaviest traffic on the hottest day of the year while putting an angry wasp in your helmet for good measure.
Synthetic oil hides your 13mm socket and puts superglue on your earplugs. Synthetic oil will scratch your faceshield and make your gloves shrink two sizes night before trackday. Synthetic oil stole your neutral and sold it to the Chinese for $1.25. Synthetic oil will make you grow a tail. Synthetic oil will write long crazy e-mails to your Internet friends and then sign your name at the bottom!"
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Re: Beware of synthetic oil
« Reply #1 on: July 19, 2016, 07:59:13 AM »
Beware!
Offline mrbreeze
  • Not your average
« Reply #2 on: July 19, 2016, 01:31:37 PM »
Cool find Steve. All the way back from 2005. I don't recall ever seeing it. I like the part that says it causes the bike to uncontrollably accelerate near police cars.
MEMBER # 257
Offline gtmdriver
« Reply #3 on: July 19, 2016, 02:24:55 PM »
The need to urinate as soon as you're fully dressed certainly resonates with me.
Offline vfourfreak
  • Do you think that's wise
« Reply #4 on: July 20, 2016, 02:40:45 PM »
I knew my ex by a different name. Clearly she has used deed poll to become Synthetic Oil. I suppose I'm not really surprised, so much else of her was synthetic.
Kev
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: July 20, 2016, 03:13:20 PM »
Sounds like it was written by a vintage BMW enthusiast.  ::)
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: July 20, 2016, 05:30:14 PM »
could it have been Wobbly?   thanks for posting all that valuable info-I, for one, will never use synthetic oil again...Larry
« Reply #7 on: July 21, 2016, 12:43:43 PM »
Where is Wobbly..probably. Out riding his Harley..
Offline MoMo
« Reply #8 on: July 21, 2016, 08:42:06 PM »
certainly not riding his Beemer
