I tore down Frankenbike this week. I'm going to get some paint on the frame and get the suspension right before I transplant in its new heart: a K2 750 motor. The rest will be F3 - side cases, tank, carbs (good idea?), except for the fork tubes, sliders and calipers that come from a 81 or later DOHC 750. The fenders and some body work will be from some other 750s within that late 70s to early 80s half decade or so, but I haven't actually pinpointed the year for each.
When I took the master cylinders off I knew I had a problem. These masters are solid. As in they will never move freely again. I didn't think that parts from a low mileage bike stored indoors could rust to deeply. Of course, as the F3 motor is frozen I should have had at least one good clue to work with.
Since actual masters and calipers from these late F bikes are pretty rare I was hoping someone could offer bolt on replacement masters from other models. I am pretty confident others have faced this before, with the relative rarity of the F bikes and all. I would refer Honda stuff, but I'm open to suggestions. The front is not an issue as any master designed to drive two dual piston calipers that mount 7/8 bars will work, how about the rear master? Also, does anyone if all Goldwings use 7/8 bars? I know early ones did, but I know nothing of later model Goldwings.
Thanks in advance for any help.
Patrick
