Author Topic: 1982 cb 650 sc nighthawk sprockets  (Read 1679 times)
Offline WFO
  • Will work for powerbands
« on: January 16, 2009, 01:27:04 PM »
Yes i look through 24 pages, my question is where is the best place to get a 17/38 set any suggestions.
        thanks in advance, wfo
82 cb650 sc nighthawk - 78 kz 650 b
Offline cb650
Re: 1982 cb 650 sc nighthawk sprockets
« Reply #1 on: January 16, 2009, 04:08:50 PM »
I order all mine from Dennis Kirk.  In the cataloge they are listed so you can see what other options you have on teeth count.
Offline WFO
« Reply #2 on: January 17, 2009, 10:22:41 AM »
bump
Offline unkle fester
« Reply #3 on: January 17, 2009, 11:06:18 AM »
it came stock with a 17/39.....which gives a final ratio of 2.29.....a 17/38 would give you a ratio of 2.24....Jeff at Z1 has the 17/38........http://www.z1enterprises.com/detail.aspx?ID=1802      http://www.z1enterprises.com/detail.aspx?ID=1789        JT Sprockets lists that a 39 rear sprocket is available though........I'm sure Jeff could get it for ya if ya have to have it....but the difference between a 2.29 and a 2.24 ain't hardly worth the trouble.......in my opinion.......
Offline WFO
« Reply #4 on: January 18, 2009, 10:20:46 AM »
It is worth the trouble if you only have a 5 speed tranny
