Last summer, I was having increasing trouble with 2-1 downshifts and not finding neutral during hot conditions on my 400F. Suspecting that warped pressure plates could be a cause (and not knowing the clutch's history), I recently istalled a new set of friction and pressure plates from Honda.
In the process, I remvoed and measured the clutch springs. My Clymer manual states a minimum length of 34mm, and all four of my springs measured exactly 32mm. I've never had an issue with clutch slip, and I wouldn't have correlated my previously stated problem with a slipping clutch or weak springs.
Curiously, this manual gives the 500/550 minimum length as 30.5mm. Far be it for the "assembly is the reverse of disassembly" people to not be thorough... but are their stated values correct? I would think if my springs were all 2mm too short I'd have noticeable slippage problems.
Also, I've had bad experience and it sounds like others have as well with HD springs requiring Herculean hand strength. The EBC springs on Dennis Kirk say they're 10% stiffer than stock. If I need to replace springs, are these reasonable or do better options exist?
For what it's worth, I haven't refilled the crankcase and tested the bike since replacing the clutch this weekend. With the engine off, it pushes in neutral and in gear with clutch pulled, and it won't budge in gear with clutch engaged.
- Matt
