Author Topic: 550 barnett clutch kit  (Read 2872 times)
Offline moham
  • .fnord.
« on: February 01, 2009, 09:01:02 PM »
Posted this question in my build thread but got nada, so here it is for the rest of the group:
Going over the Barnett clutch kit (550) and noticing the friction disks, 6 and 1. Six are at 2.7mm and the 7th is 3+mm. Looking through the shop manual for orientation of the disks and measuring the old ones, I couldn't determine where the thicker friction plate goes in the stack. The manual doesn't mention a different thickness for the friction disks. Anyone got a clue?
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Re: 550 barnett clutch kit
« Reply #1 on: February 01, 2009, 10:48:32 PM »
Thats cos Honda dont have a thicker plate so no idea
Offline meb1948
« Reply #2 on: February 02, 2009, 03:47:51 AM »
If you haven't disassembled your existing clutch assembly, I'd measure each disk as it was removed to see if one is thicker then the others and its location within the basket.  If all disks are the same thickness, I'd contact Barnett at:
http://www.barnettclutches.com/contact/
I also found this item for the CB750 in the tech library:
http://www.sohc4.net/images/c/c4/Clutch_rattle.jpg
I'll follow this thread because I will eventually encounter the same problem when I rebuild my 400F clutch.
Mark.
Mark
1976 Honda 400f
1976 Honda 750f1
1980 Kawasaki KZ1000
1989 Saleen SSC #170
2001 Mustang Cobra Convertable
Offline Grizzly
« Reply #3 on: February 02, 2009, 07:47:49 AM »
Don't know if this is any use to you.
I have just replaced the clutch on my 750 K7. Six friction plates have one part number with the remaining slightly larger friction plate using a different part number. The six smaller friction plates go in first with the larger friction plate the very last of the plates to go in.
Never worked on a 550 before so this might not apply.
The older I get the faster I used to be!!!!
Offline moham
  • .fnord.
« Reply #4 on: February 02, 2009, 09:27:43 AM »
Thanks guys, I think I'll call Barnett to double-check the specs...These came as a kit from our favorite on-line auction site so  I should make sure they are correct. I know everything else is, just not 100% on the one mystery plate.
78 750K-The Ocho
Offline hymodyne
« Reply #5 on: February 02, 2009, 09:28:44 AM »
earlier posts here have suggested just not using the 7th friction plate.
hym
Offline moham
  • .fnord.
« Reply #6 on: February 02, 2009, 06:30:07 PM »
Contacted the seller and barnett for assistance so now I wait...thanks to those that replied.
78 750K-The Ocho
Offline moham
  • .fnord.
« Reply #7 on: February 03, 2009, 03:15:49 PM »
Here's what Barnett had to say"
"The 'odd' plate installs first over the center hub. It will be the last friction to slide into the basket. The slots on your basket should be wider on the outside. The square drive tabs on the odd friction are wider than the others. It will fit in only one position. If you removed the old clutch pack, the new one will install in exactly the same order. The Honda service manual should show the correct order, too."
I'm fine with everything except the last sentence. As far as I remember, the shop manual didn't give any discussion to the order of friction disks in the basket. I may be wrong...In any case, I'll do what he says and see what happens.
78 750K-The Ocho
Offline Flying J
« Reply #8 on: July 24, 2009, 12:45:46 PM »
How did your barnet clutch work out? Im trying to decide if I want to spend the money on the Barnet clutch or do the stock.
Offline NickC
« Reply #9 on: July 24, 2009, 12:59:02 PM »
I had no odd size clutch discs on my 550, everything was the same. I went with factory stuff and barnett HD springs.....
Offline moham
  • .fnord.
« Reply #10 on: July 24, 2009, 07:28:52 PM »
I'll let you know as soon as I get it running. Had to solve the 7th plate mystery before getting everything assembled. Now the springs/actuating lever are super stiff so I need to evaluate everything once I get closer to firing...
78 750K-The Ocho
Offline elquenada
« Reply #11 on: September 14, 2009, 01:58:13 PM »
Im wondering what you decided to do about this problem.  Im in the middle of installing a set of these EBC plates:  http://www.starcycle-usa.com/servlet/Detail?no=10777.
I am having the same problem you posted about.  I installed all the plates except for the last one, the "odd sized" one and in the end just decided to put back one of the old plates.  Im not sure if this is a good idea and Im wondering what you ever decided to do and how it turned out?
TIA
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline elquenada
Odd sized clutch plate CB 550
« Reply #12 on: September 14, 2009, 02:25:02 PM »
just wanted to update.  I called Starcycle (where I bought the clutch plates) and EBC.  They both told me that for some reason the CB 550 is cross listed.  So they sell one part listed for CB550 F/K 75-78 and then they sell another listed for the CB 550 K/K1 74-75.  Evidently the later models had an odd sized clutch plate that the earlier ones did not have.  Hope this helps someone else.
1975 CB 550
Lope de Vega
Offline moham
  • .fnord.
Re: Odd sized clutch plate CB 550
« Reply #13 on: September 14, 2009, 04:33:57 PM »
Well you found out what I did by asking around a bunch. Finally someone here hipped me to the difference in clutch plate packs for later 550s. Called Barnett and the guy that sold me the kit shipped out the right plate. Clutch is now installed but possibly incorrectly as I am 3/5 of a moron. Have not yet got the bike running that the clutch is attached to...
78 750K-The Ocho
Offline elquenada
« Reply #14 on: September 14, 2009, 07:10:50 PM »
i guess thats better than 4/5 of a moron,  good luck!
1975 CB 550
Lope de Vega
