Author Topic: Gaskets and such  (Read 1281 times)
climber11
Gaskets and such
« on: October 12, 2005, 09:11:23 PM »
Howdy,
I am in the process of tearing down my first engine, and replacing the gaskets.  How do I best clean off the old head/cylinder gasket material, and what sealer do I use to put the new ones on.  Any help would be great.
Scott
Re: Gaskets and such
« Reply #1 on: October 13, 2005, 01:14:28 AM »
(1) Patience, Kerosene and a soft scraper
(2) NONE unless you want to bung the oilways up and have it sieze
Offline superchode
« Reply #2 on: October 13, 2005, 07:35:58 AM »
i just talked to my mechanic about this yesterday.
he echoed exactly what bryanj posted.  don't use any kind of sealant or liquid gasket on these older engines.  the tolerance and fit of the components isn't as tight as it is nowadays and you'll end up with that material inside your engine bunging things up.
use the proper gaskets and tighten them down to the specified torque settings - that's it.
