G'Day Mate, keep looking at eBay for a seat and you'll find one, no problemo. Re: unseizing your engine, assuming that it is seized from sitting for a while and not seized from terminal engine failure, remove your spark plugs (be careful, I've removed spark plug threads on one engine that sat with the plugs in it for many years) and tip some penetrating oil, or diesel fuel, (or both) into the plug holes and leave it overnight, or even a few days if you can.
Put the bike up on the centre stand and put the engine in gear and try to turn the back wheel forward, or rock it back and forth. Better than trying to stand on the kick starter, that can put undue strain on the gearbox components and do more damage. Don't try turning the big alloy "nut" on the ignition end of the crank, you'll just bugger it, but you can remove the alternator cover and put a bit of pressure on the rotor retaining bolt head with a spanner and a big "Jimmy Bar" for extra leverage, if you'd prefer.
Failing all the above, remove the headlight, speedo, tach and turn signals, then either point the bike down a very steep hill or get your best buddy to tow you behind his pickup, and when you get to a suitable speed, (under 60 MPH is a good idea) pop it into gear and dump the clutch! It'll either a. un-sieze itself, or b. you'll have the most spectacular "endo" and your buddy will wish he'd had the presence of mind to bring his cam-corder!
If option b occurs, I need a headlight, speedo, tach, and turn signals............... Ha ha, Cheers, Terry.
