My 1974 CB550 has been "marking it's spot" since I got it. I figured it was the shifter shaft seal because that is the general area the oil seemed to be coming from. I took off the left side cover and found a huge puddle of oil. It seemed to have filled the pocket around the oil pump. I started the engine up with the cover off and did not see anything coming out of the pump. The oil pressure light seems to be working properly (comes on with the ignition, goes off when the engine is running).
Anybody have an idea what might be going on here?
