Author Topic: wheel swaps  (Read 2183 times)
chris lewis
wheel swaps
« on: October 15, 2005, 08:30:43 AM »
hey goodfellows, i was wondering if there was a source that told what wheels could be swapped with what bikes. I have a 72' cb750k2 and i'm trying to find either comstar or some other mag
to put on. I recently came across comstars from a 80' cb400 on ebay and was wondering if they would fit any help appreciated.....thanx
        chris lewis
Offline hahnda
  • lskdfhs;dljksa;
Re: wheel swaps
« Reply #1 on: October 17, 2005, 01:33:10 PM »
Comstars off a CB400 would be awfully small for your cb750. The 400 ran a 90/90-19 out front and a 100/90-18 in back.
Maybe a comstars off a CB650?
KEvin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline dusterdude
Re: wheel swaps
« Reply #2 on: October 17, 2005, 01:38:23 PM »
uh,kevin i think thats what the k1 is supposed to run.if i remember it was a 3.25-19 tire.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline hahnda
  • lskdfhs;dljksa;
Re: wheel swaps
« Reply #3 on: October 17, 2005, 01:43:31 PM »
The K1-6 ran a 120/90-18 didn't it?. I have a set cb400 wheels at home, and those things look puny when sitting next to a CB750 wheel.
Kevin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline dusterdude
Re: wheel swaps
« Reply #4 on: October 17, 2005, 01:57:03 PM »
no,mine is a 19 and the tire chart on the rear fender says 325-19 and also the owners manual does too
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline hahnda
  • lskdfhs;dljksa;
Re: wheel swaps
« Reply #5 on: October 17, 2005, 02:03:44 PM »
On the front? I'm talking on the back.
If he wants a matching set of rims the 100/90-18 is going to be to small to run on the back. But yeah you could maybe run the 400 wheel up front.
KEvin
Kevin
CB750K4 in pieces
CB750K3 with F trim
CB750K7
CB500 Cafe Project
CB750 Cafe
Offline Geeto67
  • A grumpy
Re: wheel swaps
« Reply #6 on: October 17, 2005, 03:24:58 PM »
There were a ton of mags made back in the 70's for these bikes, lesters, morris, etc...
Most are expensive today.
For an easy swap get a 1977-78 supersport swingarm and complete front end. The front will bolt on using the 77-78 stems, but for the rear you will need a way to fab up the hangers for the master cylinder to operate the rear disc. You could try modifying a DOHC rear drum comstar but it is 16"  and I don't know what you will need to get chain line perfect.
Everything after that will require some fab work.
Maintenance Matters Most
