Author Topic: 78 cb 550 4 . what do I look out for?  (Read 6132 times)
Offline jeepurz
Re: 78 cb 550 4 . what do I look out for?
« Reply #25 on: August 24, 2009, 03:56:46 PM »
better pic of missin part.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #26 on: August 24, 2009, 04:07:15 PM »
No parts are missing.  The #2 carb has a non-adjustable slide.  Use #2 as your reference carb and balance the other three to it.
Why do you want to pull your carb bank apart?  Unless you have leaks in the fuel gallery tubes between the carbs, clean them while they are together.
The stubby brass jet is the idle jet.  On later carbs, they are pressed in.  You can pull them out with pliers.  Just be careful you don't crush them.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline jeepurz
« Reply #27 on: August 24, 2009, 04:20:26 PM »
mainly wanted to pull em apart to clean the bodies and polish em up a little, if theres a better way im in. this is Skeerin the heck outa me and im fearless.
Offline jeepurz
« Reply #28 on: September 12, 2009, 11:20:50 AM »
welp thought id post up a progress report, thanks to everyone hePPin out.
Still gotta get carbs back on back together , get tires , and wiring .
Offline jeepurz
« Reply #29 on: December 10, 2009, 06:27:01 PM »
little more update wise , hahanda (think he's a member here) and I crossed paths on another board and he redid the carbs cause I hate carbs. that said, wiring brakes and some misc is all thats left. Oh the seat , a guy from another boards stitchn that up .
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
« Reply #30 on: June 18, 2014, 12:05:12 PM »
about the timing how did you put the timing because i am thinking the timing so did you put the timing so that the you turn the crank to the tdc 1.4 and then put chain on the sprocket and then you put the sprocket on camshaft and then you turn the camshaft so the centre of cutout notch is aligned to the cylinder head flange surface and then you look how much the sprocket is off the bolt holes and then you take the sprocket back and change the sprockets teeths until you think its right and then you put sprocket back and if camshaft is turn off the timing marks place then you turn the cam right position and then you look how much the sprocket is off the bolt holes and if it is then you do again what i was sayed or how you did it?????
sorry, bad english!
« Last Edit: June 19, 2014, 01:11:41 AM by kranta »
