Dan - I've done a decent amount of bleeding over the past few years... With these brakes the only way I found fit to bleed was from the top ---> down. Open bleedport, squeeze lever, close bleedport. repeat. This has worked fine for me.. I have use syringes in the past but didnt feel it was necessary here. What system/how are you bleeding your brakes?
Also... does anyone feel that any noticeable difference will be achieved by running a similar-bore, but MODERN M/C? Due to leverage ratios, etc... thanks
EDIT: I got lots of information, but still cannot find the caliper dia and m/c dia of the stock 550k brakes. Anyone? or should I just start tearing into them to measure myself.
