Author Topic: Softening hard carb boots  (Read 84820 times)
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« on: April 08, 2009, 06:03:43 AM »
After removing the carbs on my 750 Hondamatic, found the rock hard boots are unavailable. Wrapped them in a wet towel and put them in the microwave for 2 minutes (or until steaming hot). Kept them in the towel until ready to slip them on. Slipped them on the head and carbs snapped right on.
Fonda Honda
Re: Softening hard carb boots
« Reply #1 on: April 12, 2009, 08:50:02 AM »
That is one of the 100 ways people have used to soften old rubber. It is at best a short term fix and when you are finished you will have hard boots which are not very good for sealing. I have a set that has been soaking in ATF for two years and you can crack walnuts with them. OEM new boots are still available. That may be a good long term investment.
Offline grumburg
« Reply #2 on: April 12, 2009, 03:34:55 PM »
Any help in findng 77 750 Automatic carb boots would br appreciated. Have been looking for 2 months with no luck.  :-\
Fonda Honda
« Reply #3 on: April 12, 2009, 04:01:30 PM »
Where have you been looking, should be the same as a K model
Offline Spanner 1
« Reply #4 on: April 12, 2009, 08:25:42 PM »
Bobby the 750A carb boors are 24mm, the K bikes are 28mm..i.e. the A has smaller carbs...
Offline grumburg
« Reply #5 on: April 13, 2009, 08:29:51 AM »
Not only are they smaller, but #1 and #4 cylinders are curved since carb bank is smaller. Also, 77-78 are not interchangable with '76. Part numbers for 77-78  (#1-#4) are 16211-393-020, 16212, 16213, and 16214.
Fonda Honda
« Reply #6 on: April 14, 2009, 02:39:28 PM »
I am sorry I did not realize they are that different. I guess you have to do what you have to do.
Offline Steve F
« Reply #7 on: April 15, 2009, 06:37:43 AM »
A while back, someone posted about this using some home made concoction that included "mint oil" or something like that.  I tried to search for it last night and came up empty.  Who posted this?
« Reply #8 on: April 15, 2009, 07:36:10 AM »
That is Oil of Wintergreen they are talking about. The two problems with old boots is installing them and creating a seal. If new ones are not available, you have to do what you gotta do.
Offline goon 1492
  • Sucka Repellant
« Reply #9 on: April 15, 2009, 09:33:21 AM »
Man bobby I was thinkin' about if an atf bath would do any good, guess not. :-\
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: April 15, 2009, 09:41:22 AM »
I can confirm that Wintergreen oil does the trick.  I have some pics and data from when I did some last summer, I'll try to dig it out.
The only side effects are that the boots will continue to smell strongly of wintergreen for a long time afterwards.  I have my intake boots sealed in a ziplock to keep them from stinking up the garage, and I can smell the wintergreen right through the plastic.
mystic_1
- John Augustus Shedd
Offline Steve F
« Reply #11 on: April 15, 2009, 09:54:20 AM »
mystic_1
Now you can say your bike is "mint".  ::)
Offline goon 1492
  • Sucka Repellant
« Reply #12 on: April 16, 2009, 09:17:45 AM »
Where would one find this oil at? I feel silly asking this becasue I have probably seen it in the store already and wondered " what the heck is that for?"
« Reply #13 on: April 16, 2009, 09:30:29 AM »
You can get it at a real Drugstore. Remember all of this is very temporary.
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: April 16, 2009, 10:03:39 AM »
How existential of you... :-\ ;D
« Reply #15 on: April 16, 2009, 01:01:24 PM »
Thanks, I try  ;D
When rubber compunds are mixed it is decided how elastic the part is intended to be. A certain amount of "elasticizers" are added to the mix. These chemicals are unstable and will literally evaporate out of the rubber. You cannot put them back in. What you are doing with heat and solvents is breaking down the rubber and making it temporily softer.
I went through this and Mike Reick suppled me with a new set of manifiolds. When i start the bike with the tank off you can see them beat like little haerts so they are sealing well and are that pliable.
If you are stuck because a part is not available, you have to make do. If you are a victim of this economy, soften the boots as best you can and keep food on the table and roof over your childrens heads.
If you have the $50 or so bucks to buy new ones, it is a good investment. that is all I am saying.
Have a Blessed Day Y'all
Bobby
Offline mystic_1
  • 1970 CB750K
« Reply #16 on: April 16, 2009, 01:05:59 PM »
I agree completely.  New boots are best.  That said, the wintergreen trick can squeeze out a few extra miles while you save up for the new ones.
mystic_1
Offline 6adan
« Reply #17 on: April 21, 2009, 06:14:12 PM »
I put some in mineral spirits to try and it did nothing,all other rubber I put in it would swell and get soft but these thing stayed hard as a rock.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
« Reply #18 on: April 21, 2009, 06:52:37 PM »
That is because it is a fuel proof rubber the petroleum oil will not have ant effect.
Offline swan
« Reply #19 on: June 04, 2009, 12:07:17 PM »
To soften hard rubber boots with xylene and wintergreen oil read:
http://forums.sohc4.net/index.php?topic=29707.0
1975 CB400 F cafes, 1974 CB750 K4 Cafe, 1966/1976 Triumph/ Norton Triton Cafe and 1962 DBD34 BSA Gold Star Clubman.
CB750 build http://forums.sohc4.net/index.php?topic=52551.0
Offline Toxic
« Reply #20 on: June 05, 2009, 05:36:38 AM »
[/quote]
[/quote]
Where do you get them for $50?  got a link?
Offline swan
« Reply #21 on: June 05, 2009, 12:55:52 PM »
K and F models carb insulators
 Z1 Enterprise
 set of four carb insulators for CB750 K and F models: $76.21
 Honda Parts Direct
 $76.88 for set of 4 insulators A and B
 $40.98 CB750 A model sets for Grumberg from Honda Parts Direct if they are still available.
I have been using my Wintergreen and xylene mixture for 2 years on 4 bikes and all are running and idling fine with no vacuum or air leaks. $10 worth of ingredients saved me over $300. Why throw something away if you can make it work again?
« Last Edit: June 05, 2009, 01:04:17 PM by swan »
Offline Toxic
« Reply #22 on: June 05, 2009, 06:03:46 PM »
That's great, thanks for the links.
I'll check them out.
Offline grumburg
« Reply #23 on: June 12, 2009, 02:59:16 PM »
Went to Honda Parts Direct. Web states: "We are closed and not accepting orders"  WTF?
Fonda Honda
Offline noisebomb
« Reply #24 on: June 12, 2009, 05:49:50 PM »
They (probably) have them here.
http://www.cyclepartswarehouse.com/fiche_section_detail.asp?section=124873&category=Motorcycles&make=Honda&year=1977&fveh=2978
If Honda doesn't make them anymore, they will refund the purchase price.  I have ordered a lot of parts from them (78 750K), and haven't had any trouble.
1978 cb750K
