Author Topic: Victim of poor gas?  (Read 751 times)
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Victim of poor gas?
« on: April 08, 2009, 09:14:52 PM »
My '74 550k Runs poor. How's that for vague? Starts a bit hard, when warm it immediately does not want to idle, and shortly thereafter will not run unless my hand stays on the throttle. Further, when accelerating under load it needs a lot of throttle just to pick up. I had checked last fall, but will again, some of the basics. A compression test has yet to be done as too a carb sync. I know plug reading is key and when I can get to where it's parked I'll pull 'em again. Also, I have a hard time determining what choke position it dislikes the least as it requires a bit of fiddling.
I should mention that I dropped the float bowls and they were all fairly clean EXCEPT there was a strange gelatinous substance at the bottom of each. The tank had been treated with a sealer by the PO and wondered if there's a relationship. I have drained the tank, will blast the carbs with cleaner, and will check the petcock, etc...
It has 10k on the clock, pods, and four into one. I don't have the carb tuning specs just now but it ran well before this situation. It also has two parallel in line fuel filters. I know, I know. As soon as I'm confident about the factory screen they are gone.
I just thought it couldn't hurt to put it out for other opinions and maybe trigger that little pea brain of mine into action.
Thanks for being gentle.  ;D
1974 CB550K
                                  Your 1%er name
Offline Hush
Re: Victim of poor gas?
« Reply #1 on: April 09, 2009, 12:39:33 AM »
Think you diagnosed your own problem dude!
If the carbs are full of crud, guess what those 4 wee in-line filters are full of ? ;D
She's sucking on the choke cos she ain't getting enough from the lines is my guess.
There'll be plenty of this happening as the sleeping 4's awaken for the good riding weather. :)
Offline martino1972
  • and still a expert welder,period...
« Reply #2 on: April 09, 2009, 12:39:52 AM »
I think there's your answer......little holes in little jets get plugged easy..... ::) ::) ::) ::) ::) ::) ::) ::) ::) ::)
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
