Author Topic: When do points go bad?  (Read 1425 times)
Offline Derby City
« on: April 12, 2009, 01:05:53 PM »
My question is just as the subject reads...how do you know when it's time to buy new points.  Unfortunately I don't know how many miles are on the points on the bike right now.
1974 CB 550
Offline Johnny5
    • CB350F build thread
Re: When do points go bad?
« Reply #1 on: April 12, 2009, 01:32:42 PM »
When you cant adjust the points to get the timing right will tell you that it's time for new points. Also, pitting in the points is another indication.
They arent expensive and relatively easy to replace. If you think yours arent any good, best to just install new ones.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Derby City
« Reply #2 on: April 12, 2009, 01:57:52 PM »
Yep, I think I'm having that timing issue right now...No room left to turn the circular plate the points are mounted to.  I think I saw some pitting on the points as well.  Guess I'll add new points to the parts list.  Thanks for the post.
1974 CB 550
Offline Johnny5
« Reply #3 on: April 12, 2009, 03:17:58 PM »
After you put new points in, you'll be amazed at how much easier timing the bike will be.
1971 CB350
1973 CB350F
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: April 12, 2009, 05:26:52 PM »
This may be a good time to consider picking up one of Hondaman's Transistorized Ignition setups, it reduces the power flowing through the points making them essentially last forever.
mystic_1
- John Augustus Shedd
Offline 6adan
« Reply #5 on: April 12, 2009, 08:42:38 PM »
I just put one of Hondaman's Ignition setups on a GL1000. I did not touch the points and it starts and runs better than before.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline 333
  • Time for change
« Reply #6 on: April 12, 2009, 09:13:52 PM »
Any pitting can be filed smooth with a points file.  Another issue is the slider that rubs on the cam.  If this is dry(no lube) it will wear down and require adjustment constantly.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
