Hey guys,
I have had a bear of a time with my front brake system on my bike. I have completely rebuilt the system all the way from the MC to the caliper and everything in between. All new seals, lines, fluid, and pads. I have very diligently followed all the advice in the brake FAQ, and I have posted several questions. Here are my problems:
1. brake is spongy, and I have tried EVERY possible method of bleeding, and am getting no more bubbles in the system. Any ideas?
2. brake is dragging to the point of glazing pads and scorching the rotor. The caliper arm is free, not bound up. I have lubed everything I possibly can with silicone lube, checked movement of the piston, and it DOES actually retract when I release the lever. I have tried to adjust the stationary pad, but it seems when I put both bolts in the caliper assy. that it binds up the caliper and rotor somehow. Does anyone have a diagram? Do I have my caliper arm or disc mounted the wrong way? Right now, I have the arm directly against the fork with the fender mounts, and then the washers and bolts. The disc has the hub pointed AGAINST the wheel. I am completely at a loss here!!!!! It looks correct and I haven't been able to mount anything any different way....HELP!!!!!
Thanks!
Erik
