Support the site. Your contributions keep this site running.
So I got this baby to run just fine yesterday. Installed the sprocket/clutch cable/drive cover and then went to fire it up again and nothing.
If there's oil on the cam lobe that moves the points (spark advance unit) will that cause a problem?
Two tired - you're reading my mind! I checked the timing again and the advancer lobe seems to be pushing the 1-4 points open and closing them almost exactly at the 2-3 mark. I tried to take the spark advancer apart when I had it out but couldn't.There's that pin to set it on the crank shaft, so how could I have put it back on the bike wrong? Could I have bent it when I was working it back and forth to lube it up?
