Author Topic: What late model coils are 5ohm/12 volt with replaceable wires?  (Read 1885 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
Before I beheded my 550's top end I was checking for spark, and before I could get the boot off the plug I got a shock. I checked my plug wires and found a couple small cracks. Plug wires on older 550's aren't replaceable (without a lot of surgery), so I as wondering...
What is the best candidate for replacement coils? I know they need to be 5 ohm & 12 volt. I'm guessing early 80's 750's would be good, but I wanted to check and make sure there's no resistors to remove or anything like that.
1974 CB550
Forever West
fuzzybutt
Re: What late model coils are 5ohm/12 volt with replaceable wires?
« Reply #1 on: May 01, 2009, 10:05:57 AM »
dyna makes a 5 ohm coil
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #2 on: May 01, 2009, 10:52:29 AM »
Grind away some of the Bakelite and you can get those wires out. There's a picture sequence of it somewhere... I was going to make one for the FAQs but I have Dyna coils so I've been lazy about it.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Slayer
  • What can I say that hasn't been said before
« Last Edit: May 01, 2009, 11:00:48 AM by Slayer »
Offline OldSchool_IsCool
  • Really feeling like an
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
  • The Stumped
« Reply #5 on: May 01, 2009, 10:58:58 AM »
Yeah, I saw dyna made them. I'm more interested in the ease of plug wire changes than performance upgrade. And even some of the performance minded guys were recommending GL1000 coils instead of the dyna ones as a cheap alternative, although I think some of those were 9v/ 3-ish something ohm's which wouldn't work on the 550.
Anyone know for sure that early 80's 750 coils are 12v/5ohm? No resistor? They're on eBay for 20$ all day long, which is in my budget.
1974 CB550
Forever West
Offline Slayer
« Reply #6 on: May 01, 2009, 11:01:17 AM »
Good catch, thanks
ev0lution7
« Reply #7 on: May 01, 2009, 11:16:43 AM »
i actually am in the middle of making my "old" 5 ohm cb750 coils into having replaceable wires were you interested?? all i've got is yellow accell 8mm spiral core wires though ;D and they are 150ohms per foot (about half of a regular wire) and tey have GREAT Suppresion..
$20 and thier yours... they are stock cb750 coils i'm making them with the above mentioned accell wires...
the second pic is of my GL1000 coils with the same yellow wires...
« Last Edit: May 01, 2009, 11:37:10 AM by ev0lution7 »
Offline Patrick
« Reply #8 on: May 01, 2009, 11:30:59 AM »
I am running coils from an early 80s VF750 on my K0 750. They are 3 ohm.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
  • The Stumped
« Reply #9 on: May 02, 2009, 10:57:03 AM »
Well just got a response to some eBay units I was watching... '80 750C units are 3 ohm.
Were any of the 750 coils 5 ohm?
1974 CB550
Forever West
Offline winnipeg550guy
« Reply #10 on: May 02, 2009, 12:01:43 PM »
Found It, I new I saved this info somewhere for my own use as well
 http://forums.sohc4.net/index.php?topic=17310.0
74\' 550k., 1965 Suzuki K15, 1978 BMW R80/7
ev0lution7
« Reply #11 on: May 02, 2009, 12:02:05 PM »
look at my post a few up  ???  i said you could have MY 5ohm coils for a price... thier from a Cb750 and like i said if you dont mind YELLOW wires or if you just want me to leave them blank...(you add your own wires) then i can do that...
  • The Stumped
« Reply #12 on: May 02, 2009, 12:45:57 PM »
Thanks for the above link, sorrry, I thought the original post implied I was looking for replaceable plugs. I have good 550 coils if I want to do the epoxy method, I was eyeballing 750 coils because I thought they had replaceable plugs, but it looks like the ones with replaceable wires are 3 ohm. Thanks though.
1974 CB550
Forever West
