Author Topic: steering head bearing question  (Read 1623 times)
kelly_s
« on: May 02, 2009, 11:19:01 AM »
i need to do the steering head bearings on my 1975 cb750 and i was wondering if the same parts numbers for the 1971 cb750 will work. ive been looking at http://www.stephenbottcher.net/Honda/tapered.htm and i am about to order the parts. thanks a lot.
billybobobrain
Re: steering head bearing question
« Reply #1 on: May 02, 2009, 11:24:30 AM »
UTFSE
ev0lution7
« Reply #2 on: May 02, 2009, 12:03:42 PM »
PLEASE READ THE FAQ!!!!!!!!!!!!!!!!!!!!!!!
serious please read!
Offline ofreen
« Reply #3 on: May 02, 2009, 01:25:22 PM »
Yes they will.  You're welcome.
Greg
'75 CB750F
Offline cleveland
« Reply #4 on: May 02, 2009, 01:48:52 PM »
It's his first post, cut him some slack.  8)
billybobobrain
« Reply #5 on: May 02, 2009, 01:54:39 PM »
Offline ofreen
« Reply #6 on: May 02, 2009, 02:02:16 PM »
Yup, it is easier to answer his question than it is to give him some static.  And maybe then he'll stick around.
Greg
'75 CB750F
Offline Johnie
« Reply #7 on: May 02, 2009, 03:04:40 PM »
I see this is your first post Kelly.  Welcome to the board.  There is a ton of info here and in the FAQ section.  Surf the site and I am sure you will like it.  One thing you will find out...we like pics.  As soon as you get a chance attach some pics of that 750 for us.  Again, welcome aboard!!! ;D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: May 02, 2009, 08:07:12 PM »
Except for the gauge mounts and other small changes, the triple trees are all essentially interchangeable from 69-76, and possibly into 78 as well but I'm not sure about that.  They went a little happy on changing things in the k7 and k8.
Lots of good info floating around about the install process, too.  Use the search page http://forums.sohc4.net/index.php?action=search and look for "tapered", that should give you lots of results.
Also do read the FAQs http://forums.sohc4.net/index.php?board=11.0, the mods do a great job of distilling things.
mystic_1
- John Augustus Shedd
Offline Hush
« Reply #9 on: May 02, 2009, 09:00:54 PM »
Welcome aboard Kelly-s, don't worry they don't bite after a while and show them some pics and they even sit up and beg. :D
Offline moham
  • .fnord.
« Reply #10 on: May 02, 2009, 09:24:05 PM »
UTFSE
Use Teflon Forged Snot Envelopes? I honestly don't see how that's going to help him, although I haven't read the FAQs yet either...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
kelly_s
« Reply #11 on: May 02, 2009, 10:03:43 PM »
i read the FAQ but i didn't see anything that said that the years 1971 to 1975 had the same part number. i was in a rush to get the parts here so i thought that i could ask a simple question that required i simple answer. sorry if i inconvienced anyone. i will definately get some pictures up. everyone says the bike is looking good. thanks for everyone that responded. good or bad
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
« Reply #12 on: May 03, 2009, 10:14:30 AM »
I used All Balls Racing Products steering stem tapered bearings with nice results!
part#20-1011. They also have cross reference #'s for other distributor's
Their phone # 1-888-228-3323, from their 2004 catalog.   Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline Jakoba
  • I'm far from a CB750
« Reply #13 on: May 03, 2009, 05:17:37 PM »
Hey kelly welcome aboard.
I just replaced the bearings on my 78 750K and I used the article that Hush wrote as my bible.
The article is called; "ALL BALLZ tapered steering bearings for non experts." You will find it using the search engine. ;)
PS: What a difference in the handling of the bike....you'll love them bearins'. :D :D
Jako
Jako
Member #4500
"See the ditch, see the ditch, in the ditch"
