Author Topic: 78 CB750F  (Read 1555 times)
DavidSS
78 CB750F
« on: May 18, 2009, 07:14:41 PM »
Hello, I hope you guys are friendly. I bought two bikes from my neighbor. Hes about 85 and bought the bike new.  One is a 78 CB750F that has been sitting for a few years. It has a 836cc kit with a thousand miles on it and a new pipe on it. The bikes total mileage is 17K. The other is a CB 750K parts bike, motor stuck, ragged. The F model appears to have a K bike rear fender instead of the correct rear tail section. Iam not sure why this was done and he cant remember but the bike has been set up for touring with bags and a fairing. I would like to put it back to the correct way its supposed to be. Ive got the carbs apart right now but need to source some of these body parts, where? Any help thank you
Offline BlackMax
Re: 78 CB750F
« Reply #1 on: May 18, 2009, 07:29:51 PM »
an 836 cruiser?  When I bought my '78 f2, it was a "cam'd 836".   When I opened the motor up, it was a OE cam'd 750.   ;D
Body parts, particularly side-panels, for a '78 can be a challenge to find.  Some are expensive.  For mine, I have been trying to find the left side cover for some time.  Fast forward 3 months....no luck.   I have a rear fender I would sell for essentially nothing, but you'd need alot more.  The only source I can think of would be EBAY, piece by piece over time.  ?
1978 CB750SS, 4-1 Yoshi, Pods, 3-angle valve job, ported chambers, ported intake, 41a cam
Offline eurban
Re: 78 CB750F
« Reply #2 on: May 19, 2009, 03:47:31 AM »
What color / number is the motor?  836 kits engineered for the 77/78 big valve F motors are relatively rare although they were made; you might have a big bore K motor installed in a F chassis (not a bad thing at all), or a standard 836 kit installed in an F motor (a bad thing, not enough compression) .  F model engines have issues with exhaust guide wear; hopefully if your motor is an F it was rebuilt correctly.  Biggest symptom is a smoky motor.
« Last Edit: May 20, 2009, 03:40:56 AM by eurban »
Offline cafe2be
Re: 78 CB750F
« Reply #3 on: May 19, 2009, 07:54:35 AM »
I also have the rear fender, taillight and maybe a few other pieces I took off my 77 750f. I would send them to you for the cost of shipping. As for the side panels, there is a company (cant recall off hand) that remanufactures the side panels. I have also seen them on ebay. I recently found a guy in Upstate NY that has some 750f he is parting. his name is chris, houghracing@yahoo.com. Great guy.
Offline CrescentSon
Re: 78 CB750F
« Reply #4 on: May 19, 2009, 08:07:12 AM »
I too have a '78 F, but I'm not going for stock.  Let me know what you need, and i might be able to help.  (Side covers are a no-go though, sorry)
-Daniel
Offline Blasbo
Re: 78 CB750F
« Reply #5 on: May 19, 2009, 10:36:12 AM »
People here are very friendly and helpful unless someone cops an attitude (which is very rare).
I'm sure I saw it here first, but http://lpmreplicaparts.com/ has repop side covers for £28 each. I haven't ordered any so I can't vouch for them.
Offline cafe2be
Re: 78 CB750F
« Reply #6 on: May 19, 2009, 10:38:28 AM »
thats the company blasbo. Heard decent things about them.
DavidSS
Re: 78 CB750F
« Reply #7 on: May 19, 2009, 07:35:03 PM »
I guess you guys are friendly, good, and thanks. The bottom end of the motor is black but the top end is unpainted. K top end maybe? I dont need side covers just the rear end stuff and a seat. Its got a hideous huge ugly seat on it now. This bike has stock paint which is a kinda dark red or maroon color. I need to finish up on the carbs so I can get it running, maybe next week hopefully. The tank needs derusting big time. I thought about trying the electrolysis method, any of you all ever tried it?
ev0lution7
Re: 78 CB750F
« Reply #8 on: May 19, 2009, 09:15:20 PM »
welcome to the forum!!! sounds like you got yourself a killer bike!!!
just take the carbs apart and dip them in carb bath (can of carb cleaner) and take them out a few hours or maybe a day later! get a repair manual or download them here and enjoy!!
Offline BeSeeingYou
Re: 78 CB750F
« Reply #9 on: May 19, 2009, 09:40:50 PM »
The electrolysis works great for getting the corrosion out.  Check out the last few pages on the thread in the tricks and tips section. I have done two tanks for myself and a few for friends.
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
Re: 78 CB750F
« Reply #10 on: May 19, 2009, 10:29:37 PM »
I have switched to Yamaha carb cleaner works good and not nearly as toxic or corrosive,rubber parts haven't melted? Tanks, the first thing to do is see how much crud,
can be removed first. A very bad tank last summer took about a week for me to get it clean,
from rinsing to get all the oils and varnish out, then rinsed and dry gravel from my drive way
for shacking to remove as much of the rust as possible then rinse and repeat till the heavy stuff is gone then about two days in electrolysis bath,on and off to check on the progress and make new solution. Clean as a whistle, I also have had good luck with acids,the easier way is electrolysis. As soon as the tank is clean let it dry ,like in Strong sun, then put about
1/2 cup 50/50 mix of gas and oil in the tank and get all of the inside coated with it.
I use (Berkebile  2+2  instant gum cutter/carb cleaner, works better than gum out! 42 years
of doing this stuff and I have never have creamed a tank and won't,if I think a tank needs lined I'll find another tank?  Just some thoughts from my neck of the woods.
                                                 Head
PS I don't use any in line fuel filters? PS AGAIN WELCOME ABOARD!
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Re: 78 CB750F
« Reply #11 on: May 19, 2009, 11:06:50 PM »
Repro seats are available on EBay. Just keep an eye out. If you need the cowling/tail piece too you're going to have to beg or be patient and watch EBay daily for used.
Offline Flying J
Re: 78 CB750F
« Reply #12 on: May 19, 2009, 11:21:34 PM »
I have a seat for sale minus the tail light. It was just professionally recovered and is black. PM me if interested. And just to let you know we love pictures so lets see this bike.
