Author Topic: HELP! K5 lower tree K8 upper?  (Read 1042 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: May 19, 2009, 09:27:11 AM »
will the lower tree from a K5 align with the upper tree from a K8 and fit on a K1?
Re: HELP! K5 lower tree K8 upper?
« Reply #1 on: May 19, 2009, 09:31:41 AM »
No, keep them in sets.
Both will fit on all years, but 77/78 set on 76 and down will cause tubes to touch on stock tanks.
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: May 19, 2009, 09:34:40 AM »
my K1 tubes touch my dunstall tank now  :o
it's not an issue since I'll be welding some stop tabs soon
  • Like a well oiled
    • Undead Asphalt
« Reply #3 on: May 19, 2009, 09:37:23 AM »
my problem is I have a K8 top tree and it doesn't fit with the k1 bottom.
 the K8 is a 1/2 inch closer to the neck.
« Reply #4 on: May 19, 2009, 09:44:43 AM »
Correct you cant mix either of the late parts, with the either of the early ones.
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #5 on: May 19, 2009, 09:46:12 AM »
I have a set of 78 trees that I'm using as paper wieghts. You can have em if you want em, but you gotta pay to ship.
jim
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
  • Like a well oiled
    • Undead Asphalt
« Reply #6 on: May 19, 2009, 09:47:04 AM »
jim
PM me with your paypal dude, I'll take em
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #7 on: May 19, 2009, 10:13:14 AM »
I believe the K model triples have a 60mm offset and the F models have a 50mm offset. I would think the K8 to be as per the F model.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
