Author Topic: Moved the handle bars now I haven't any headlights.  (Read 1540 times)
Offline mrblasty
  • Expertly
« on: November 02, 2005, 11:44:20 PM »
As the title says any Ideas where to look?
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline mcpuffett
Re: Moved the handle bars now I haven't any headlights.
« Reply #1 on: November 03, 2005, 01:32:17 AM »
hi, try looking in the headlight thats were most of the wires connect ;) how far did you move the bars? mick.
MetalHead550
« Reply #2 on: November 03, 2005, 06:00:49 AM »
What are you on again?  My 75 has a switch for the headlight.  Perhaps you pulled a wire loose there...if you have one.
Offline KB02
« Reply #3 on: November 03, 2005, 06:08:15 AM »
That would be my suggestion, too look for pulled out  or unplugged wires. Did you just move the existing bars or did you put new ones one? In either case, there may have been a wire that sharted out against something in it's new position.
Have you checked your headlight to see if the bulb is still good? Could be a blown bulb and just a coinsidence that it happened when it did.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline mrblasty
  • Expertly
« Reply #4 on: November 03, 2005, 10:19:29 AM »
Forgot to mention it was cb 750 k3, The bulb looks good. Just moved the stock bars back an Inch to Fine tune my grasp.
1973 Honda CB 750
1975 GL 1000
Offline mcpuffett
« Reply #5 on: November 03, 2005, 01:30:39 PM »
have you checked the fuse? mick.
