Author Topic: Anyone one with 350F petcock parts?  (Read 714 times)
Offline TomL
« on: May 27, 2009, 07:18:39 PM »
Looking for the bottom petcock bowl for my 350f.  Mine seems to have sprung multiple leaks.  If anyone has one let me know.
Offline many408
Re: Anyone one with 350F petcock parts?
« Reply #1 on: May 28, 2009, 05:54:55 AM »
Whaddya got, pinhole leaks or a bad seal?
Bad seal, get a new gasket.  Pinholes, wipe the inside with Seal-All.
Offline TomL
« Reply #2 on: May 28, 2009, 08:03:51 AM »
More than a pin hole.  The drain screw in the bottom is stripped and there is a sizable hole in the side as well.  I have temporarily fixed it with a drill a tap and some set screws, as well as some JB weld for good measure.
Offline kghost
« Reply #3 on: May 28, 2009, 09:51:12 AM »
The bowl is the same as the 750.
The difference between the petcocks are the outlets....SIngle to the side vs double then down.
Stranger in a strange land
