Author Topic: Trickle battery charger?  (Read 2051 times)
Jim Shea
« on: November 08, 2005, 07:31:29 AM »
Anyone using a trickle charger or similar? I have seen solar ones available are they any good?
Any problems to be aware of when using these type of devices?
Jim.
« Last Edit: November 08, 2005, 11:42:22 AM by SteveD CB500F »
Offline dusterdude
Re: Triclkle battery charger?
« Reply #1 on: November 08, 2005, 07:59:28 AM »
jim,get something automatic like a battery tender.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Jim Shea
« Reply #2 on: November 08, 2005, 08:05:09 AM »
Mark,
Sorry, can you explain what a battery tender is, over a trickle charger, and a brand name?
Jim.
Offline dusterdude
« Reply #3 on: November 08, 2005, 08:08:51 AM »
battery tender is the brand name.what it does it automatically maintains the charge in your battery.clicks on when it needs to then clicks off.very good product
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: November 08, 2005, 08:17:15 AM »
You can buy Bettery Tender in UK but I've only seen them on eBay.
Try Optimate
http://www.accumate.co.uk/it010003.html
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
« Reply #5 on: November 08, 2005, 09:32:20 AM »
Mark,
Jim.
A "charger" could be anything that delivers power.  It's exact function can only be derived from its specifications.
There are fast chargers, chargers, trickle chargers and float chargers.
The difference is generally the rate at which energy is provided to the battery, and relates to the battery capacity or C.  C is derived from the battery's discharge rating and relates to the current it is expected to deliver.  The CB750, for example has a 14 Amp Hour nominal rating.   A fast charger could be 10C through 1 C (140 through 14 Amps).  A matched-to-battery charger would be 1/10 C or 1.4 amps. A trickle charger would be 1/100 C (0.140A or 140 milliamps).  And a float charger would be something like 1/1000 C.
Ideally, a good device would put the bulk of the charge in a battery at the 1/10 C rate, then switch to a 1/100 C rate for thorough chemical saturation of the battery, and then switch to "float" mode to maintain the battery at peak charge.  These devices are often called "tenders".  As you might expect, a marketing department has actually used that term as a brand name for their product, too.
A battery does not store electricity per se.  Electricity is consumed or produced in a chemical reaction.  The conversion process generates heat as a by product comensurate with the rate of conversion.  Quickly discharging or charging generates heat which can damage the battery.  Also, delivering a charge current to a battery that is already at full capacity expends the excess energy as heat also.  To prevent damage to the battery, operator inteligence and attendance is required, or a device that can automatically sense what the battery needs and deliver only that energy that will keep the battery in peak condition.
Here is a pointer a more to a more thorough explanation.
http://www.yuasabatteries.com/yuasa05/faqs.asp
I have several chargers for multiple bikes.  My most recent acquisition was the following automatic 3 level charger that I am very happy to have.  However, if i lived in a climate that had wide temperature swings, I'd get one that was temperature compensated in addition to the automatic functions this one provides, as the voltage produced by the chemical reaction in the battery varies with temperature.
http://www.chaparral-racing.com/Chaparral/productr.asp?pf%5Fid=321%2D2101Y&gift=False&HSLB=False&mscssid=423AE45782D74E22AC521578D16C68FA
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: Trickle battery charger?
« Reply #6 on: November 08, 2005, 01:42:11 PM »
The battery Tender products are def. the way to go.
Quality product that will last for years , and will help keep your battery going for years...
Whenever my ass is not on my bike riding , the bike is plugged into the tender.
Keeps the battery at a constant 12 volts , and ready to go.
