Author Topic: What Tool Do You Use ?  (Read 842 times)
jumpjg
« on: June 02, 2009, 07:30:39 AM »
Last week I got my project '77 CB750F back on the road after going through the brakes, swingarm, forks, steering stem, switches, alt/trans/clutch/pan gaskets/seals, clutch, etc. I did not remove the carbs because it seemed to start & idle just fine. Now that its on the road I've realized that a carb synchronization and idle mix adjustment might smooth out the idle a bit.
Last night I attempted to adjust the idle mixture using a small, short pocket screwdriver (stock carb/ airbox configuration). For reference, the idle mixture screw on these carbs is located on the bottom downstream from the slides, in front of the float bowls. I was successful in accessing the mixture screws for #1, 3, & 4 carbs but #2 was a no-go. I  just didn't have enough room to fit my fat hand(s) in there to access the screw. It looks like I need something like a right angle screw driver. Any recommendations appreciated.
Joe in St Louis
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: What Tool Do You Use ?
« Reply #1 on: June 02, 2009, 07:40:56 AM »
I use a screwdriver bit (the ones for drills or whatever, hex) to reach up there and do those.
No.
Offline Inkscars
  • grumpiness comparable to an
« Reply #2 on: June 02, 2009, 07:41:30 AM »
When I'm adjusting those air mix screws I hold onto a little flat head bit and adjust it that way. I've also got a flathead screwdriver that I cut off short and bent near the tip  that fits pretty well. Now that I have  the secret to install a whole carb bank in about 30 seconds, if i have anything i need to do in the bowls, I just pull the whole set.
81 Hardly Davisson
Offline robe0531
« Reply #3 on: June 02, 2009, 07:47:22 AM »
here is a link to the tool i use thing is the best
here is link for 1
http://street.parts-unlimited.com/21/169/7859778?q=screw%20driver
« Last Edit: June 02, 2009, 08:00:28 AM by robe0531 »
1978 cb750k
1968 Honda ca160
