SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Sidecovers
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Sidecovers (Read 3394 times)
Bricktop
Guest
Sidecovers
on:
April 18, 2005, 07:38:01 AM »
I am wondering if anyone Knows where I can find a set of reproduction sidecovers (fiberglass?)for a 1970 CB 750 I just picked it up and only found one set on ebay over the weekend So thanks and have a great day
Logged
SteveD CB500F
Global Moderator
Old Timer
Ride on the Steel Breeze...
Re: Sidecovers
Reply #1 on:
April 18, 2005, 07:45:06 AM »
Try
www.davidsilvers.co.uk
Alternative list of parts suppliers in the "General FAQ"
Logged
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
kghost
Really Old Timer ...
www.facebook.com/RetroMecanicaAustralia
Re: Sidecovers
Reply #2 on:
April 18, 2005, 06:10:05 PM »
Classic Motorcycle Supplies.
www.cmsnl.com
regards,
Kghost
Logged
Stranger in a strange land
cb750_chris
Guest
Re: Sidecovers
Reply #3 on:
April 18, 2005, 06:48:14 PM »
The repro side covers have pros and cons. Pro being they are new and ready to paint. Con #1 being they are not the white easy to mend plastic the originals are made of. Con #2 I have heard they just look a little odd if you match them up with the originals.
Logged
kghost
Re: Sidecovers
Reply #4 on:
April 18, 2005, 07:21:01 PM »
Repro item I got for my K2 was a better plastic than the original. More flexible therefore less prone to cracking? It was dimensionally the same as the original, could discern no difference.
Logged
cb750_chris
Guest
Re: Sidecovers
Reply #5 on:
April 18, 2005, 08:39:56 PM »
The K0 vented repro covers are the ones I meant. The white plastic the originals are made from bond super well with two part plastic weld. They can get old and brittle though. If you get the repros get them as a set and know that they might be spotted by an expert if you care about that.
Logged
Big Bob
Hot Shot
Re: Sidecovers
Reply #6 on:
May 05, 2005, 04:13:36 PM »
Wow. OK, does anyone know where I can find a set of repro K0 sidecovers for less than ~$90 a pop?
Logged
-Big Bob
Chicago, IL
www.chivinmoto.com
www.vinmoto.org
Dragman836
Full Member
0-115 mph. in 11.07 sec.
Re: Sidecovers
Reply #7 on:
May 05, 2005, 04:59:54 PM »
JC Whitney has them @ 23.99 each you can order online@
www.jcmotorcycle.com
Logged
"ADD NITRO" , Just Do It!
Big Bob
Hot Shot
Re: Sidecovers
Reply #8 on:
May 05, 2005, 05:33:29 PM »
Would you mind giving me a part number to search by? I can't find any side covers on their site at all, let alone K0 stuff. I know they have sold side covers for the later years in the past but I can't find them on the JC Whitney site.
Thanks!
Logged
-Big Bob
Chicago, IL
www.chivinmoto.com
www.vinmoto.org
Dragman836
Full Member
Re: Sidecovers
Reply #9 on:
May 07, 2005, 07:12:48 PM »
The part #s are: AGL060315W(RIGHT) & AGL060316U(LEFT) IT SAYS THEY FIT 71-76 CB-750 THEIR TOLL FREE PH.# IS 1-800-853-4227
Logged
eldar
Guest
Re: Sidecovers
Reply #10 on:
May 08, 2005, 08:44:15 AM »
you may also be able to try
www.crc2onlinecatalog.com
. I got my covers from here and they are molded a bit different and screw on instead of pop in tabs that break. The screw ins are a bit hard to anchor though. They paint decently though and with mild trimming they fit pretty good. I only have a problem with the right side which is where the oil tank is.
Logged
Big Bob
Hot Shot
Re: Sidecovers
Reply #11 on:
May 13, 2005, 02:24:12 PM »
Neither of these do me any good. These are the same products made by Maier, in both cases for '71 and later models. I need a set for a '70 which uses a larger cover with louvers cut into it.
Thanks anyway.
-Bob
Logged
-Big Bob
Chicago, IL
www.chivinmoto.com
www.vinmoto.org
dpen
Hot Shot
Re: Sidecovers
Reply #12 on:
May 14, 2005, 11:22:14 AM »
As an aside - rubber grommets from the local hardware store fit nicely in to give you new mounting rubbers for your new sidecovers (soak in hot water before fitting)
Logged
Tim.
Master
www.DOTHETON.com
Re: Sidecovers
Reply #13 on:
May 14, 2005, 01:42:20 PM »
RE: grommets - depending on your attention to detail, the grommets are still available from Honda for a few bucks. On the 550F there are some oblong ones, so I'm not sure a trip to Home Depot would do much good.
Logged
Roule comme dans les années 70... Roll as in the Seventies...
dpen
Hot Shot
Re: Sidecovers
Reply #14 on:
May 15, 2005, 06:34:53 AM »
Round grommets become oblong ones when they see the hot water before they get pressed into the lugs
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Sidecovers
