Author Topic: Repainting side covers... do they need to be stripped?  (Read 1588 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: June 10, 2009, 07:09:08 AM »
Does the old paint have to come off before repainting?
If so, how do you strip plastic w/out melting it?
Could they just be cleaned, scuff sanded, and repainted right over the current color?
Offline tygrant
Re: Repainting side covers... do they need to be stripped?
« Reply #1 on: June 10, 2009, 07:15:21 AM »
I meticulously sanded mine smooth and repainted them over the old paint.
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline tlbranth
« Reply #2 on: June 10, 2009, 07:43:14 AM »
Years ago I used paint stripper on my side covers and air box. It destroyed them. It was still the 70's and I got replacements cheap from a cycle salvage yard in Seattle. When my neighbor painted my bike for me recently, I first sandplasted the parts. Then he sprayed on a heavy primer which I very meticulously sanded. That was then sprayed with the finish coats. Looks great. My neighbor restores old cars for a living and is very good at painting.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline nobody
« Reply #3 on: June 10, 2009, 09:27:06 PM »
If the old paint is sticking fine you don't need to strip it, just sand them smooth and get out any nicks or scratches. You'll want to prime it if you sand anything more than a dime sized spot down to the plastic.
74 cb750k
Offline grumpy
« Reply #4 on: June 10, 2009, 10:14:22 PM »
cool
thanks!
« Reply #5 on: June 10, 2009, 11:02:22 PM »
If you can see bare plastic you need something called "Adhesion Promoter" (at least thats what they call it in UK) first or the flex will make the paint fall off
Offline ChrisR
« Reply #6 on: June 10, 2009, 11:21:15 PM »
Also, if you do sand and repaint, check that the new paint doesn't react with the old. Perhaps put a blocking or sealing coat (barcoat) on first anyway to make sure.
Chris
ChrisR
1977 CB550F
1975 CB550K
