Author Topic: clutch basket adjustment.  (Read 944 times)
Offline 4 BANGER
« on: June 11, 2009, 08:39:22 PM »
My son did a motor rebuild on my 71 CB 750 and the clymer book said torque the clutch basket bolts to 7 lbs which he did and we ran it to night and it slips. The free play is fine. But he did say that after he torqued it to the 7 lbs that it seemed to loose. Does any one have a diff torque setting or is there a diff way?
Thanks.
Learn from other peoples mistakes, you won't live long enough to make them all your self.
justjosh
Re: clutch basket adjustment.
« Reply #1 on: June 11, 2009, 09:24:21 PM »
    My uncle was a tech for a local honda m/c dealer for about 20 yrs and i have his shop manuals from when he was there. In the clutch section it says torque value 7lbs and under that he hand wrote "re-torque to 12 to 14lbs" You might try that but you definatly dont want to over tighten cuz that will open a whole nother can-o-worms and you might check your plate's to make shure there in correctly
Hope this helps
Offline 4 BANGER
« Reply #2 on: June 12, 2009, 06:18:57 PM »
Thanks for the info. He had made them tighter but then you cant pull the clutch. On a dirt bike you just tighten it all tight and the springs set the tention for you. This threw us of a bit. We will try the 12-14 lb and let you know.
