Author Topic: New blinkers=blown headlight  (Read 760 times)
Offline brett_bike
  • '73 CB500 Four K2
« on: June 24, 2009, 08:34:41 PM »
So...as the headline reads, all blown.  Headlights are a Lockhart Phillips single filament marker light, I'm pretty sure I hooked them up correctly.  I followed the instruction on the back of the packaging and tucked the solid black (runner) wire into the housing so as not to ground out.  A wire connector must have came out and touched something.  Any suggestions on where to start?
Thanks
Offline Spanner 1
Re: New blinkers=blown headlight
« Reply #1 on: June 24, 2009, 08:57:42 PM »
Start with the fuse, it's blown ?...O.K., open the h/l shell first and look for some mis-placed wire vs. wiring diagram... big fat wattage halogen h/l will maybe pop stock h/l fuse......whats the wattages on hi/lo? Solid black on these bikes = + Battery voltage ( nominally 12v).
Offline brett_bike
  • '73 CB500 Four K2
« Reply #2 on: June 24, 2009, 09:09:33 PM »
Fuse is good.  I can see that the headlight is blown and all the directional lights.  This sux, I never had this problem when I was running it WO blinkers.  The headlight is from BikeBandit  dot com and it only has one setting, it is only on when switched to high beam.  I've been running it like that since last year with no problems.  If there is one thing I can live without, that one thing is figuring out electrical problems, rather bash my face against a brick wall.
Offline Spanner 1
« Reply #3 on: June 24, 2009, 09:49:08 PM »
Well, new blinkers, no mater what, wouldn't cause yer h/l to blow...that's a separate issue...Night Owl Poster's might help you further....us oldfolks ( who rode 200 miles today) are going to bed......!
