Author Topic: Point gap open or closed?  (Read 1566 times)
Offline Heirborn
« on: November 13, 2005, 05:45:01 AM »
I recently purchased a '70 cb750. After a new battery bike starts fine but does not fire on cyl 2&3. Last weekend it "healed" itself and was running strong. This weekend it is back to the same problem. I have a few questions but lets start with this. Clymer says to rotate to the "F" for fully open, which I did and adjusted the points. However when I continue to turn the crank the points open further before closing. Another article that I read says to rotate until they "are" fully open. So which is true? Also,  are both sets or point supposed to be open at the same time or is one supposed to close while the other is open?
'70 CB750-Open Pipes and Pod Filters
'72 CL70
'07 Bonneville
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Point gap open or closed?
« Reply #1 on: November 13, 2005, 06:10:54 AM »
Go to the FAQ section and look for Manuals,there you can download the Honda Maintenance Manual.
Gap is set on the highest position of the camlobe , not at the F mark.
The F mark is where the points should start to open.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline Dennis
« Reply #2 on: November 13, 2005, 08:20:23 AM »
If you set the point gap like that, you would be lucky if it even started.
Scout
« Reply #3 on: November 13, 2005, 11:14:56 AM »
You just have to turn the crankshaft until you see the biggest gap on the points, and measure it there. As one opens, the other one will close, so make sure that you measure each one separately, then remeasure them again just to make sure.
Scout
Offline Heirborn
« Reply #4 on: November 13, 2005, 01:25:38 PM »
readjusted the points and all is well.
thanks for everyones help.
'72 CL70
'07 Bonneville
