Author Topic: misfire on No3 cylinder 400/4  (Read 1131 times)
tony darburn
« on: November 13, 2005, 12:07:22 PM »
Hi i have completely stripped my carbs on my 400/4 and replaced all the internals and cleaned thoroughly,they are now on the bike and set up , the bike fires up ok and runs but no 3 cylinder is not firing properly,i have checked the timing and points , compression and valves all seem ok but have run out of ideas now, has anyone got any ideas i can try thanks  Tony.
Offline hymodyne
Re: misfire on No3 cylinder 400/4
« Reply #1 on: November 13, 2005, 08:02:35 PM »
check for spark with a spare plug in the #3 wire. check that plug wire to see if its screwed into copper wire, or just rubber insulation.
hym
"All things are ready if our minds be so."
tony darburn
« Reply #2 on: November 14, 2005, 02:33:10 PM »
Thanks will give it a go 8)
